Message |
My thought are, you only have one Wideband. The Idle mixture will be different side to side.. so the lean you are seeing on the Drivers Bank, COULD be also a rich on the Passenger Side.. Only a Second Wideband will tell.. In that case it would LIKELY be a Throttle Body Adjustment on the Passenger side open too Far, as the Passenger Side T-Body controls the Air on the Drivers Side Cylinders.. Cj
![](/themes/01/images/spacer.gif) |
